britt
(britt)
May 19, 2020, 6:00am
1
I am a student currently using Bootcamp to run Rhino 6 on Windows 10; on my 13 inch early 2015 MacBook Pro. Every time I try to pan/rotate, my entire system crashes (not only Rhino) and I cannot move my mouse. I have to manually shut down my mac by holding the power button.
I noticed I cannot download Apple Boot Camp Software Graphics Drivers from AMD (https://www.amd.com/en/support/kb/release-notes/apple-boot-camp ) because my mac does not have a GPU. I am new to this and was wondering if a GPU is required for most architecture applications (as I plan to download AutoCAD and Revit as well).
What are my best options to have my Windows 10 partition to function regularly with Rhino and other rendering softwares?
Thanks!
gankeyu
(Keyu Gan)
May 19, 2020, 6:03am
2
You should be able to run everything with CPU-based graphics, but everything would be so slow.
In your case I guess your computer needs a deep cleaning (physically).
jespizua
(José Espizua)
May 19, 2020, 6:12am
3
These two software are very demanding in terms of graphic power. I don’t think your computer will be powerful enough to properly run those softwares.
May I ask why are you using boot camp instead of using OS X? You can run Rhino and Autocad on OS X, and given your system, I think it’ll work better natively.
wim
(Wim Dekeyser)
May 19, 2020, 8:26am
4
HI Britt - in addition to what has been said so far, could you please run the Rhino SystemInfo command and copy-paste the result here?
britt
(britt)
May 19, 2020, 3:57pm
5
Hi, I have recently partitioned my Windows to have 500 gb, and I haven’t used much so far.
britt
(britt)
May 19, 2020, 3:59pm
6
I am learning Rhino on the windows interface, so it’s easier to follow along on windows.
britt
(britt)
May 19, 2020, 4:01pm
7
Rhino 6 SR25 2020-4-23 (Rhino 6, 6.25.20114.05271, Git hash:master @ f35d7ded15ec317635ced435d8df84327397038d)
License type: Evaluation, build 2020-04-23
License details: Cloud Zoo. In use by: (BC)
Expires on: 2020-08-09
Windows 10.0 SR0.0 or greater (Physical RAM: 7.9Gb)
Machine name: DESKTOP-VNECM0M
Non-hybrid graphics.
Primary display and OpenGL: Intel® Iris™ Graphics 6100 (Intel) Memory: 1GB, Driver date: 9-29-2016 (M-D-Y). OpenGL Ver: 4.4.0 - Build 20.19.15.4531
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.4
Shading Language: 4.40 - Build 20.19.15.4531
Driver Date: 9-29-2016
Driver Version: 20.19.15.4531
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.25.20114.5271
That’s a very old Intel Iris driver on a marginally supported graphics chip.
Here’s a link to update your Bootcamp display drivers.
That’s what I’d do next.
From March 25th
If your Mac says the driver isn’t “validated” for your computer, here’s how to fix that hogwash:
Intel’s graphics drivers will refuse to install on some computers, even if they use Intel graphics chips. If you see this error message, your computer manufacturer wants you to install drivers from their website, not directly from Intel. But there’s...
Any luck?
britt
(britt)
May 20, 2020, 4:58pm
9
It seems to be working fine so far! Thank you so much!
