Hi all, hoping there is a fix to my Boolean Issue issue.
There seems to be a bug with Boolean union and or the merge face command in Grasshopper. I have geometry that when I bake it, Boolean it together, and then merge the faces/edges the geometry is perfectly clean and what I want. If I run the same through grasshopper then I get extra polysurfaces I can not clean up even though they are co-planar.
I’d like to either:
-Use a .rs command within a python script inside of grasshopper to use the rhino Boolean union instead of the grasshopper one
-Or find a way to work through grasshopper to get rid of the faces.
I’ve uploaded my grasshopper file - it is the Breps in the group called “Fascia” that I’m trying to boolean together. Any help would be much appreciated!!!
FloorBuild-DD100_simple.gh (110.0 KB)
