Hello everyone, I have a problem with the model I need to create. I should combine three elements. In Grasshopper and Rhino there appear to be no problems, but when I load it into the 3D printing software, CURA, some layers do not print and an error is indicated in the model. I would be grateful if you could help me and find out what the problem is because I can’t understand it. I thank you in advance and i will upload the grasshopper rhino and cure files
bolean union 12.01.24.3dm (4.5 MB)
bolean union 12.01.24.gh (43.0 KB)
cura file.stl (1.2 MB)
First step to try is ShrinkWrap everything together into one piece.
Thanks a lot, but is it a grasshopper plugin?
it could be that there were problems in the boolean union. Try looking for a command (in rhino or grasshopper) that will do a more precise merge
It’s a command in Rhino 8 and a component in Grasshopper
