Bongo waves wont animate,
Hi there,
Im trying to make a simple water animation doing it exactly as what is done here
But for some reason it just wont animate, it refuses to remember the 0,0,10 offset for 50 and 0,0,0 for 0, nothing happens in the viewport,…
Sabino,
This is unfortunately due to a bug in Rhino 5. It has already been fixed and the fix will be in Service Release 10.
Ok, i figured that.
Will service release 10 be out anytime soon, we bought bongo because we have to do an animation using waves.
And it has to be finished this week (or next),…
Could i maybe go back to an older Service release to avoid this for now?..if so which?..
Sabino,
It got broken in SR9 so for example SR8 should be fine.
Ok thanks, one more thing, how do i go back to sr8 :smile:
Also, i was rendering 1400 frames over the weekend, this morning it was doing 2:30min for a frame, when i closed rhino and rebooted, it took only 1:30 for the same frame, i think maybe rhino remembers every camera position and caches it somewhere? or does this have to do with the bug too, i have animated water in it,…
I was able to find sr3 i think, my cd is sr0 and i have sr1 somewhere, would any of these work?..
Unfortunately no, Bongo 2.0 requires SR 5 or later in order to install, since it uses the new licensing system that was introduced in SR 5. I’ll send you a download link as a PM.
What if @Sabino tried using the Service Candidate 10?
I have sometimes used the next SR in advance and have had good results.
