Animated Water with Bongo & Vray (Figment water displacement maps)
I am trying to animate water with the Figment water displacement map packs in Vray+Bongo. Everything looks great in a single rendering, the map is set to Sequence in Vray, but won’t animate, the water will just stay on the single frame. Anyone know what is needed on the bongo side for it to pick up the full map sequence?
Hi Erik, I’m not familiar with this workflow but if you can post a file with the issue i’ll take a look. Thanks
Bongo supports the animation of the displacement map in Rhino, but if V-ray is using something else than Rhino’s displacement map, than Bongo won’t register the change.
