RIL
(Rolf)
1
After rotating the Pivot a couple of times I notice that I have no clue of its exact current( and thus “reference”) angle.
So, if I want to adjust the Pivot rotation, I will start from an unknown (only approximate) angle.
How do I restore the Pivot directions to that of the World space for a fresh new start?
// Rolf
Luc
(Luc Adriaenssen)
2
Select the appropriate object
Click the “Rotate pivot” button in the Bongo Properties pane
Alternatively you can use the BongoRotatePivot command
on the commandline you’ll see a “Reset” option
Angle or first reference point <0> ( Reset ):
click on it or type R (or r) + Enter
Parallel workflow for BongoMovePivot.
