Sorry for all of the posts I’ve recently started using to Bongo 2 and so far I love it FAR more than 1.0 but have not figured out all the ins and outs. One problem that has persisted is being able to pivot on an axis that I have moved. Using the “move object pivot” command and its “3points” function, lines the axis up the way I want it. But then when I go to animate it will rotate as if the axis was never tilted. If anyone has a work around or solution to this that would be much appreciated.
https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/7/2/7261f54c8f5b56b827be3e4ae20c19946fd9338f.MP4
