I’m looking for a way to rotate the object pivot like I can move it because I like to animate an object in z-direction of the turned pivot.
Ciao,
Micha
Ciao,
Micha
Micha,
An object’s pivot can be rotated with the BongoRotatePivot command.
The button is in the Utilities section of Bongo’s Object Properties.
I don’t know what exactly you have in mind, but notice:
Hi Luc,
thank you for all suggestions, more than I hoped to get.
So there is no direct way to move the card along the object axis away from the paper fan? I need a quick out-in-movement. The cards are the child of the deforming paper fan. My hope was to animate along the aligned z-axis.
I can switch to object space, but it is still using the world space.
Best-
Micha
OK Micha, I think I see the problem.
The trick is to make the moving objects (cards?) child of a proxy (a dummy object, mostly a point) and then rotate the proxy rather than rotating his pivot. In demo.3dm (72.1 KB) you see (under A) a moving line being child of a rotating point. Under B the proxy is firmly rotated by adding a rotation datum only in keyframe 0. I guess a multiplicity of such a systems © is what you need. Of course the proxies in turn can be child of a master object (the fan?) making them move or rotate simultaneously (tick 40 till 50).
Wow, detailed example. I understand. Working with proxy objects - very helpful.
Is it a bug that we can switch between object and world coordinates, but the transformation doesn’t follow the pivot object coordinate arrows?
No bug. The current situation (move = Worldspace, rotate = selectable, scale = Objectspace) exists since version 1.0
All 3 transformations available in Worldspace as well as in Objectspace would be far more logic, consistent and user-friendly. It is definitely on my wish-list for version 3.0
Sounds like an old bug.
Marika or Andy, can you help?
