Using blockedit command over block with additional block references causes geometry disappeared. See video
Steps to reproduce:
open example.3dm
use blockedit command
edit text
hit Apply changes in Blockedit window
see result
example.3dm (4.4 MB)
pascal
(Pascal Golay)
January 30, 2017, 4:35pm
3
dan
(Dan)
March 28, 2017, 8:13pm
4
This bug should be fixed in the latest RhinoWIP (5E63w) . Please give it a try. Thanks again for reporting!
Hi, this bug is still in the rhino 6!
Reproduce:
have a block
use “block edit” command
click on the name of the block, in the block edit window, once or twice
all geometry except the block IS ERASED INSTANTLY
wim
(Wim Dekeyser)
June 27, 2019, 12:44pm
7
Hi - I’m seeing a different issue here but nothing gets erased.
Could you please run the Rhino ‘SystemInfo’ command and post the result here?
Also, could you provide a bit more details for step # 3?
Thanks,
Note: what I’m seeing here is described in RH-53478
Hello Wim,
I am putting it here. I replaced the situation.
step 3 : clicking and deselecting the “Bin button” (image)
System info:
Rhino info.txt (2.7 KB)
After step “3” boxes were erased
Finally, I was trying to save a copy of the file, and even the block was erased (or hided?)
Bin block test.3dm (5.2 MB)
Thanks
dan
(Dan)
July 9, 2019, 11:47pm
9
RH-53478 should be fixed in the latest RhinoBETA . Please give it a try.
