BlendSrf needs a Curve option to blend to a curve, not only edges of surfaces. This would be analogous to the Point option in BlendSrf. Of course if the Curve option is selection only position matching would be available at the curve.
Current work-around: create a temporary surface with the target curve as an edge, typically using ExtrudeCrv. Use BlendCrv, then delete the temporary surface.
