hi,
i am designing a diving tower and i want to blend the main volume and the additional volumes for the platforms seamlessly, as if it was only one big volume. i have already tried making holes on the main and connecting the edges of the additional surfaces with loft, blendsrf, patch, and even networksrf.
loft gives a very close solution to what i want, the problem is that it gives these sharp creases.
the pipe trim workflow, albeit a large version of it will be your friend here.
trim a hole in the main forms, then trim the platforms back to make a gap that defines the shape of the blend you want. Then use blendsrf to fill in the gaps you created. /
Creases like this, in my experience can occur when you’re asking Rhino to create organic compound curvature using degree 1 information when it should be degree 3 information.
I would recommend analyzing the input data and checking the degree.
Also, I’d recommend checking the composition of density of points within that data to determine if you’re also asking Rhino to compile extremely inconsistent densities of data together, i.e. if one curve is say 20 point density and one is 200 point density.
And, checking whether they’re poly-‘lines’ or poly-‘curves’ or have kinks in the original curve network etc.
Hence, rebuilding curves etc. will help determine a more consistent and compliant data set to create a geometry with less creases – imo.
I personally have a ‘work mode’ display mode that shows as much data as possible i.e. isocurves etc.
Without more information, those are just my initial ponderings on this matter.
As mentioned here, you can use SubDFuse in Grasshopper and QuadRemesh to do this.
The fusion works just for two SubD objects at a time. You’ll have to do the fusion in sequence for all your platforms.
Doing this with Grasshopper allows you to use SubD’s with vastly different subdivisions and do changes basically anytime. Make sure to also check the new Sharp command in Rhino 8 WIP.
I noticed that you use some very bright display mode that makes it difficult to see the general shape of the model with deep shadows and highlights. You may take advantage of using some custom viewport mode that could represent your designs in a more contrasty look. Here are plenty of nice display modes to choose from:
