Blank file when using output type vector as printing
Greetings,
i have the following problem that when i print as Rhino PDF (or any other PDF) i get blank pages in the preview and also in the final pdf. When i raster the output everything works as usual.
Sad Printing Noises:
Mildy better but still sad because of rasterized output printing noises:
I already found to other threads but they had either zero replies or were´nt helpful for my problem.
The problem there was, that the Viewport was outside of the model, so it printed truly blank space.
Vector Output to pdf blank
print-to-pdf-creates-blank-pdf
Hope you guys can help, and i´m not doing any embarrassing rookie mistake.
Anyways best regards
Z-Trick
Hi Cedric -
We’d at least need a 3dm file so that we can see what’s going on.
Always also provide the output of the Rhino SystemInfo command.
That said, unless those are separate hatches and curves, I’m not sure what result you would be expecting from vector output here…
Thank you for the reply.
Here is the 3dm and the System Info:
BTW each “pixel” is one seperate colored surface (see image). Do i have to make it 2D to work? Because i thought thats what export as vector does automatically.
Surface
BlankPDF.3dm (3.3 MB)
SystemInfo:
Rhino 7 SR33 2023-8-22 (Rhino 7, 7.33.23234.14341, Git hash:master @ b9f912e46331b381b681e79693b7a3844d72f6e5)
License type: Studentenlizenz, build 2023-08-22
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display: Intel(R) UHD Graphics 770 (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
Primary OpenGL: AMD Radeon RX 640 (AMD) Memory: 4GB, Driver date: 6-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 23.7.1.230626
> Accelerated graphics device with 6 adapter port(s)
- Secondary monitor attached to adapter port #0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 6-26-2023
Driver Version: 31.0.21001.45002
Z-Buffer depth: 24 bits
Total Video Memory: 4075 MB
C:\Users\cwehren1\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Karamba3D\2.2.0.180\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.33.23234.14341
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.33.23234.14341
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.33.23234.14341
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.33.23234.14341
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.33.23234.14341
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.33.23234.14341
C:\Program Files\Rhino 7\Plug-ins\export_PDF.rhp “PDF Export” 7.33.23234.14341
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.33.23234.14341
I think it would work if the surfaces were hatches.
Hi -
Thanks.
A few comment.
When I open your file, the detail in the layout is set to the Wireframe display mode. Based on your images here, that means that you use a custom display mode on your end.
You are printing with the “Print Color” active, which is white.
That is the main reason why your PDF output is blank.
When you use “Display Color” instead, with the detail in Wireframe mode, the result is a vector PDF that shows colored edges of the surfaces.
As Martin says, for the “surfaces” to be exported to vector PDF, those would need to be hatches.
Allright, i used indeed a custom viewsetting.
Thank you all for the input.
