After installing latest release I get this message when trying to insert a bitmap
Unable to open bitmap file - unknown file typeThe specified file cannot be identifed as a supported type.
never happende before.
What file format? Is maybe the bitmap file in CMYK format? Rhino can only open RGB format bitmap files as far as I know.
format is RGB jpg.
I managed to open only a png file
You are inserting the .jpg with the Picture command? That seems to be working OK here qith a couple of quick tests. Is it just this one image, or is it not possible with any jpg image?
am doing with drag n drop as usual, no jpg are working, include those that were doing ok before.
OK, just to check, can you try first running the Picture command, then browsing to your jpg image as an alternative to d’n’d?
What changed between “before” and “now”? Rhino update? Windows/driver update?
– Mitch
yes, as I wrote at the start of the topic, It ahppended after updating the software. Picture command doesn’t work either.
Hi - please run the Rhino ‘SystemInfo’ command and paste the result here.
I once downloaded an image from the internet that also had the extension .jpg and had the same problem as you. I think that image has some bitmap problem even though it can still be opened and viewed on a computer normally.
I have a way to handle the above problem as follows:
What I found as problem is that the software don’t have the right access permission to the file where image is hosted.
So you can try changing the place of the folder with the desired images to be imported, or giving the right permissions to the software.
It worked for me after lot of tryies saving the image in different formats.
