I have a new problem. Can’t insert any material from Rhino materials library.
When the material library is opened - no file appears in the category of “all supported format” type,
I can see all files if I choose “all files” file type, but then Rhino don’t recognize it…
I attach a print screen of the problem.
Until today it was all perfect
Can someone please help ??
Hi Rachel- can you hit F2 and copy the last 10 or so lines from the command history in the situation shown in your image? The command history looks a little odd, I’d like to see what it says in more detail.
Loading Neon for Rhino, version Aug 23 2013 05:19:36
Loading V-Ray for Rhino, version 2.00.25962
Loading Rhino Render, version 1.50, Feb 26 2015, 11:46:10
Command: _Box
First corner of base ( Diagonal 3Point Vertical Center ):
Other corner of base or length ( 3Point ):
Height. Press Enter to use width:
Display mode set to “Rendered”.
Creating meshes… Press Esc to cancel
1 extrusion added to selection.
Unable to open bitmap file - unknown file type1 extrusion added to selection.
Command: ViewCaptureToFile
Unable to open bitmap file - unknown file typeUnable to open bitmap file - unknown file typeUnable to open bitmap file - unknown file typeCommand: ViewCaptureToFile
Command: '_UndoView
Command: '_UndoView
Autosaving file as C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\5.0\AutoSave\RhinoAutosave.3dm
Autosave completed successfully
Command: _CommandHistory
I have tried reopen Rhino - No change
I have tried shut down and reopen the computer - No change
I have tried Disable VisualArq, Vray, SimLab, and reopen Rhino - No change
Ohhhhh… I don’t no what to do…
I THINK I FOUND IT OUT !!! IT LOOKS OK NOW !!! HAPPY
I think I just made something wrong in the Sequence of the orders.
I am sooo thankful to you !!! You always so helpful. Thank you very much.
Sorry for bothering…
