matthew.wj
(Matthew Wj)
February 6, 2025, 4:06pm
1
No matter what I do, I get the same error when I try to place a picture using either “Picture” or BackgroundBitmap."
I’ve tried placing .png, .jpg, .tif, and .bmp. I’ve tried all the numbers of bits (8, 16, 24, 32) I’ve tried RBG and Grayscale.
I always get the following message:
“the specified file cannot be identified as a supported type”
Any other ideas?
I’m saving from Photoshop 20205 26.1.0 release on a Mac running OSX Sonoma 14.7.3
Here are the Rhino and machine details:
Rhino 8 SR7 2024-5-13 (Rhino 8, 8.7.24134.03002, Git hash:master @ 215e2aecc0d8fbc7e0448df10b8ce818dac77137)
License type: Educational, build 2024-05-13
License details: Cloud Zoo
Apple macOS Version 14.7.3 (Build 23H417) (Physical RAM: 32GB)
Mac Model Identifier: MacBookPro18,1
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Pro
Color LCD (1728 x 1117 @ 120.00Hz)
wim
(Wim Dekeyser)
February 6, 2025, 4:38pm
2
Hi Matthew -
Matthew Wj:
Any other ideas?
Can you post a bitmap that we can use to troubleshoot this issue?
Matthew Wj:
Rhino 8 SR7
Please update to the current 8.15 version.
Please post the entire output of the SystemInfo command.
matthew.wj
(Matthew Wj)
February 6, 2025, 4:43pm
3
Thanks. Here’s the full output. I can update, and here’s one of the files I tried to load attached.
.NET 7.0.0
Graphics processors
Apple M1 Pro
Studio Display (2560 x 1440 @ 60.00Hz)
USB devices
Apple: USB3 Gen2 Hub
Apple Inc.: Magic Keyboard with Numeric Keypad
Apple Inc.: Studio Display
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.7.24134.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.7.24134.3002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.7.24134.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.7.24134.3002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.7.24134.3002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.7.24134.3002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.7.24134.3002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.7.24134.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.7.24134.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.7.24134.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.7.24134.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.7.24134.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.7.24134.3002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.7.24134.3002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.7.24134.3002
matthew.wj
(Matthew Wj)
February 6, 2025, 4:57pm
4
And I updated to 8.15.25019 and still getting the same error message.
I also tried doing a “save as” from a different image program than Photoshop, and it still didn’t work.
Japhy
(Japhy)
February 6, 2025, 5:07pm
5
I was able to download your image and insert via the Picture command.
Lets run the Reset command in Rhino and go back to factory settings. Please save settings for support button the dialog as well.
matthew.wj
(Matthew Wj)
February 6, 2025, 5:21pm
6
Done. And unfortunately seeing the same error message with both a .bmp and a .jpg (the one I uploaded).
RhinoSettingsForSupport.zip (69.3 KB)
Japhy
(Japhy)
February 7, 2025, 2:31pm
7
Thanks, can you go into Rhino8>Settings>Plugins and see if there any that not enabled? the only other variable i can think of is MacOS, i’m running 15.3.
Here is a similar report, converting the cmyk to rgb was the solution. .TIFF Support Gone? - #5 by Holo
