Bike Urbana - Rhino6/7wip/Keyshot8
Nice work, and like the high level of detail.
Thank you! First I made each piece individually and in the end I mounted the bike, then I put each piece here.
it looks very much like a rendering to me, but just to be sure its not a misunderstanding, it would be good if you would add a bit of a description and what you rendered it with.
either way, nice work.
good work
in terms of details I have nothing to say
except that I feel that it lacks environmental reflection and a little light
did you put an hdri environment?
Thank you! I simply layered the objects in Rhino and saved as normal, then imported into Keyshot and applied the materials and environment to render.
Yes, I used Keyshot’s own HDRI and the global lighting and didn’t apply any light, I have difficulty with rendering. I just like to model objects :slight_smile:
Hi @omarchagas
If you haven’t already watched it, take a look at Tim Feher’s excellent video on product rendering in Keyshot: https://youtu.be/qmk1SjdL0Vo
It’s a set of earphones, but there’s so much you can learn from this guy!
HTH, Jakob
Yes @Normand, I’ll watch, thanks!
