Hello! I have a problem with my render output in vray. I want to make an exterior scene of the building in an eye level poiont of view. I am trying to place the building in the center (same amount of ground and sky above and below) but it can’t fit in the viewport and if I rotate the view it damages the perspectives. So how can i make the render output bigger than the viewport? I tried changing the aspects in vray render output but I still can’t figure it out. Thank you in advance!
I’m not sure what you try to get, but if you want to keep your view and want to get more space around, than you get it by setting a wider camera angle.
Did you try to keep vertical edges upright? If yes, than the lens shift function could help you too.
