Bigger dimension units as default
Hi. I work only in millimetres, doing products. Every time I need to use the dimensions my typeface is extremely small. Is there anyway to have as default (when I launch RH) the height size that I want ?
Thanks :slight_smile:
It’s probably best to make your own template, with a dimension style applied to it, then each time you make a new model use that template as your starting point
