looking for a plugin to generate a bicycle chain - any ideas?
searched food for rhino but no joy.
many thanks
many thanks
what exactly should this
in be doing?
I’m thinking… flow along a curve for a bike chain?
yes, so maybe no need for a plugin then? or should it contain premodeled elements?
ArrayCrv might also work since these are stiff elements in a joint.
Perhaps this old thread will give you some ideas?
ok sorry to ask again, seems simple but I not getting it…
want to flow chain along a curve…Chain.3dm (564.9 KB)
Cool.
Don’t forget that the curve length needs to be a multiple of the pitch.
you lost me Jeremy?
I was wanting to say that if you need the chain to join up into a loop, as on a bike, the length has to be a multiple of the distance between the connecting pins.
In the following picture the links are arrayed on two circles: the top one closes because the circumference is a multiple of the link pitch, the bottom one doesn’t, because the circumference isn’t a multiple.
(Although, strictly speaking, the length of the curve needs to be slightly more as the links form chords rather than lying on the curve. Making it hard to calculate…)
