Link necklace in different positions
Hello, I’d like to know the best way to draw a chain link (jewelry) and have it follow a curve I’ve drawn, which will be the outline of the neck.
I want to draw the link and have different curves (paths) to illustrate the necklace in different positions. Thank you in advance.
Check out Flow Along Curve (Flow command).
Good luck!
Thanks, using ‘Flow’ works, but I think I wasn’t clear in my question, sorry. Do I need to create the total length of the necklace or is there some command that repeats a single link along the way?
Flow and Flow Along Curve are the same command, right?
Although not directly applicable to your question you might find this 10 year old thread very interesting:
There was also this thread:
it’s amazing what you can come up with by searching this discourse with a bit of imagination of search terms.
