Bezel Set Ring
Ring design is considerably hard. I started with something simple and reasonably ugly…
Rhino 8, Cycles, and hard use of shrinkwrap, which is fantastic for this sort of thing.
I wanted an almost “used/second hand” look, so it is slightly faceted and tinged.
This looks fantastic.Did you render it with cycles rhino or in Blender?
Many thanks!
This is done in Rhino Cycles.
Hello David,
Is there any chance you could post the file either before you applied the shrinkwrap or after applied but still with the original geometry in the file? I am curious as to why you felt you needed to use the shrinkwrap command.Seems that you could achieve closed NURBS objects prior to covering the ring shank to a mesh.
Thank you,
Andy
I believe he used shrinkwrap for the rendering / polygons.
Hi there!
Richard is 100% correct. It was really a modelling aid; cheating if you would. I was doing some speed modelling, so I decided that instead of fettling fillets, I’d just Shrinkwrap my way to the final model.
Cheers.
Hello David and Richard,
Thank you for the explanation. Appreciated.
Andy
Realistic! Keep it up!
haha, yeah, ring ugly as you said, but the render job is fantastic! :heart:
