I’m trying to blend the corners of this design into the circular band to make it seamless (when I cast it in metal it has an unsightly sharp corner). Any advice would be much appreciated. I’ve included a sketch illustrating what I’m trying to do
it looks like you want the round to dissolve into the hard edged detail somehow but it is not clear what the intent is right there - If you can decide what that transition should look like it will be a lot easier to see how to model it.
My guess is you want to start with something a little cleaner, maybe like this, where the thickness and band thinckness match up:
Hello - it’s a bit of fiddling but it starts with making the band thickness and the detail thickness the same and positioning them so that they correspond cleanly like in my top image. What you have is this:
