Hello everyone,
In my system editpythonscript command is not initializing the editor panel. Also none of the commands or macros that include running this command doesn’t work either.
Has anybody else the same problem?
Hello everyone,
Why aren’t you using the _ScriptEditor?
Old scripts that still just work in it?
It’s workin’ here…what happens when you run EditPythonScript?
Is the IronPython plugin enabled and loaded?
Martin, I have a lot of aliases written in the older versions of rhino and all is set using EditPythonScript. I don’t want to convert them to _ScriptEditor, although that can be done with AI really fast, it should be working anyway, right?
Thank you for the feedback…
When I type EditPythonScript, the interface freezes for 1-2 seconds and then nothing happens…
What is written in the command line history?
editpythonscript
enter
nothing happens…
Okay so that doesn’t sound like it’s not working, there should be an error message if something didn’t get installed(which seems to happen sometimes,) it sounds like the window is popping up in some invisible inaccessible location.
no, that’s wrong. When I run an alias which includes lines
RunPythonScript "some_file.py"
This command also isn’t working.
And what shows up on the command line when you run an alias?
When I type runpythonscript and browse to select a file it runs.
Just the editpythonscript window doesn’t come up. Technically I could edit it with scripteditor and still run it with runpythonscript command. So that should make a difference…
Then I’m telling you it’s what I said. The window is there you just can’t get to it, it’s been an issue for me before, it’s an ongoing issue for me actually, when I move back and forth between other apps the editor can just stick below Rhino and I have run EditPythonScript repeatedly to make it visible… If the script editor was not installed there would be an error message trying to open it.
I ran EditPythonScript command
Entered into task manager.
I don’t see the Rhino Python Editor instance under Rhino 9 BETA…
Okay…run SystemInfo in Rhino and post the result…
Here it is…
Rhino 9 SR0 2026-9-1 (Rhino 9 BETA, 9.0.26244.12303, Git hash:master @ 5007fbd7b46c04cee8e766232af7a8896598fb4e)
License type: Commercial, build 2026-09-01
License details: Cloud Zoo
Expires on: 2026-10-16
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET Framework 4.8.9310.0
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA Quadro P2200 (NVidia) Memory: 5GB, Driver date: 6-12-2026 (M-D-Y). DirectX(11)
Accelerated graphics device with 4 adapter port(s)
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26244.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26244.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26244.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26244.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26244.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.26244.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26244.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\import_GHS.rhp “General Hydrostatics (GHS) Import”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
That means the window isn’t open and hidden away. Your SystemInfo shows that the Iron Python plugin is loaded but the Window isn’t there after running the command. I recommend that you run Repair on your R9 Beta installation. Close the Beta and go to Windows Settings - Apps , find the Beta and select Modify, then the installer will run and give you the Repair option. See if that fixes things.
Note that a Repair is different from reinstalling and does stuff the latter doesn’t so they are not interchangeable.
I did repair
restarted
run command again
Still nothing happens and also no entry in the Task Manager.
It is okay guys, I think I’ll wait for the new BETA. I can’t use it the way I want anyway because of some shortcuts not being imported from the old settings…
