Hello, I want to create a bend animation in Rhino 7. Is it possible to make the animation in Rhino and then export it to keyshot?
Thank you
Thank you
for animations you will need to use bongo-
Do you know if I can export it in an .abc file or similar in order to have that animation in Keyshot and render it there?
Other options:
1.) If it’s a simple part & bend you can do it frame by frame. Bend the part in Rhino, export part into Keyshot & render. Bend further, export into keyshot again etc. Sometimes on a basic part like a plastic hinge it ends up being manageable.
2.) Alternatively do the deformations in Blender - mesh deformations are easy to work with and being able to adjust the falloff etc. makes it a good option.
you could also do that in grasshopper, not sure how that will work with exporting to keyshot, but i assume you could bake each position (frame) and render that in batch.
but since keyshot is a plugin maybe there is a way to render each frame directly in Rhino? or render with cylces? or just use a different app?
