Beginner Problem: How do I optimize this?
Renaming components (SUnion as Combined) is a bad idea as it will cause confusion. It’s better to rename only inputs and outputs.
There is rarely a single best way to write code. As you get familiar with data trees, you will find ways to get the same results with fewer components. I connect text panels to component outputs temporarily to examine them and use this ‘Tree/List Viewer’ tool when I want to examine geometry:
