1.Is it possible to add new categories into Coordination Settings for batch copy/monitoring??
2. Can the component “Element Curve” read the boundary-type?(Walls, Floors etc) because It looks like it’s could be used for “curve”(Columns and Beam etc ) but it’s not possible when I use it into boundary, any further idea?
Hi Japhy,
In my case, I would like to create a function for cutting all elements like a cake because the construction join in the project. I hope it would easily split all elements by a way.
If there are structural framing(Curve-Type), it work well.
I would also recommend combining filters vs using the list item like you have in your example. The list item index [?] is going to change as the list gets bigger or smaller.
