Hi there :),
I have groups in rhino with geometry that have different properties. How can I re-create the geometry with its original properties before I re-create their groups in Human?
Cheers,
Jeremy
Hi there :),
Hey @jdelavaulx, can you try including a sample file to help us understand your problem more effectively? What is it you are trying to do?
Do you want to recreate the geometry with a different grouping? If so, I am pretty sure you can just manipulate the ‘Group indices output’ and merge all properties again in the ‘CreateAttributes’ component and connect this and the Geometry to the ‘Bake Geometry’ component. The difficulty here is keeping the tree structure exactly the same throughout the process.
ps. This component or cluster ‘AssignPaths’ is unknown to me.
Hope this helps.
