I have come across this dwg. In Autocad it opens correctly. There are no duplicates of solids. When i import in Rhino, there are multiple duplicated overlaying solids. The cause is that in dwg the solids are parametric and rhino imports all the subparts.
I think since rhino does not support parametric modelling, only resultant geometry should be imported not all subparts. If it is possible. …
parasolid.dwg (444.6 KB)
