@BrianJ and others, I am having issues with parametric blocks exported/saved from AutoCAD into a dwg and dxf file (tried both). After importing them to Rhino, I see all the options geometry of the parametric block at the same time (see screenshot Rhino below). The same file opened in AutoCAD web seems to work. I am receiving the files from a third party and cannot make any adjustments to them, neither can I share them here. I already asked them to check their export options, to no avail. Is anybody else having the same issue or knows a solution? Thanks for your help.
Screenshot of block imported in Rhino
Screenshot of block, DWG file opened in AutoCAD Web Testversion
