AutoAlignCplane toggle
If I have an object selected then run AutoAlignCplane (which was previously in an off state), it seems like the Cplane should align to the selected object.
Instead, you have to deselect/reselect in order to get the plane to adjust.
In contrast, if Auto is on then you select an object (as in, it’s working properly)… then you run AutoAlignCplane, it will update accordingly/instantly and go back to normal (while leaving the selected object as selected)
The second example is good… the first one could copy the behavior by ‘doing something’ immediately upon completing the command.
hope that makes sense
fwiw, this is a sweet tool/ability…awesome idea
Yes, that makes sense. I think I fixed this yesterday so it should be resolved in the next WIP. It was logged here.
Great, thanks
I’ll look out for it in the next version.
