The feature request is on the list as RH-30155 and is dependent on a different issue.
OK. I hope you (mcneel) will come up with one and only good solution to this which is as follows:
-to every layout there will be unique printing options
-in layouts panel next to print there will be new âprint selectedâ button
-once you hit it it will export all the layouts selected
-âprint selectedâ will have few options if to merge in one pdf or each layout one pdf and how the naming convention should be (layot name + prefix suffix etc)
this is basically what even poor autocad has had since probably long time ago.
