Auditing Objects Fail
I’m having a recurring issue but cause doesn’t seem to be consistent. I’ll be doing something in the model (cutting and pasting, starting a render, canceling a render, or some other common action) and all of the sudden Rhino will lockup and down at the bottom of the window, VisualARQ will show a progress bar that says Auditing Objects and it never proceeds past 0-1%. I’ve had this happen several times today which is a major issue since it causes me to lose all work since my last save and I have no clue what is causing it. Any ideas?
Hi Scott, is there any way or are any steps to follow so we can reproduce this behaviour? If you send us the model you are experiencing this issue with to visualarq@asuni.com we will try to fix it.
Thanks,
