I was checking if it is possible to associate named views with clipping planes but I got into some confusing behavior.
As shown below, not all clipping planes work (PLAN1 and PLAN3 are wrong). I tried to reset them, re save the views, switched on and off “Named views set clipping planes” in options, nothing is working. Also,If i select a clipping plane i don’t get all the views available in the list.
Try switching between views. For me, in PLAN0 the red box is cut, in PLAN1 the green should be cut but i only see the red, in PLAN2 i see the 2 blue boxes cut, in PLAN3 i should see the 3 blue boxes but i still see the ones below.
If i associate them correctly and then i change the viewport as shown below, the cplane will stay the same, it will not change together with the viewport
It becomes confusing because some Named Views might not be visible in the viewport layout. So the clipping plane might be associated with some of them but, because they are not visible, they don’t show in the Views Clipped list.
Also, if i go to Plan 0 view and i switch the view to Perspective, the clip plane will start to cut into Perspective and it will get associated with the perspective view.
I don’t think they are meant to work as I imagined.
