Assign material UI selection RH WIP & RH 7 difference
Hi, just a slight annoyance that might grow together with the project size.
In Rhino 7 when assigning material from the list, one doesn’t need to preselect (left-click) on the material to switch to material and then assign it.
In Rhino WIP we must left-click on the material to select it and after that right-click to bring in the menu, then assign material.
Rhino 7 follows more natural logic, just like in the Windows system.
I think the video shows it best.
Rhino WIP material and rendering UI are getting a overhaul, so expect things to change still. That said, lets tag @maxsoder here so he can say if that change was deliberate or accidental.
Yes, this is a bug in the WIP. I created a YT issue for it. https://mcneel.myjetbrains.com/youtrack/issue/RH-67127
I have now fixed https://mcneel.myjetbrains.com/youtrack/issue/RH-67127.
The issue affected also Rhino Mac so the fix went into v7 also for the Mac. For Windows this fix should be in the next Rhino v8 WIP release.
