Arraying along surface in Grasshopper
Hi guys, I want to array this geometry along this surface, does anyone know how can I array it along this surface?
Thanks
Could you make it so that I could download your file? That way I can use the same geometry. :slightly_smiling_face:
Hi Ryan, could you tell me what I need to do so I can try and do it myself first? thanks in advance.
Not a clue! Just thought Id give it a shot.
Array on surface.gh (34.3 KB)
Here is the file, essentially I first want to array it along any surface, then I have another problem which is I want to distribute it along a hexagonal mesh, but that’s for another time, let me know how it goes, thanks.
Will do!
This could be one way.
Array on surface_re.gh (14.5 KB)
Wow, you’ve certainly done an amazing job here, genuine life saver, thank you so much.
If you don’t mind I’d like to ask you a further question regarding this, is there a way to deform the initial hexagon grid? into something like this?
essentially I am trying to create the facade of Beijing National Aquatics Center using the hexagonal mesh that I have.
Otherwise thank you so mush for the help.
Wow! Well done!
I can’t thank you enough for this, I had no hope.
Just as a final question (I promise), is there a way I can incorporate this mesh into the script or it is not possible?
Thank you.
Array on surface_re (1).gh (71.3 KB)
Array on surface_reV2.gh (70.8 KB)
Holy hell, you are a wizard, thank you so much. <3
