I am hoping someone can help me with a problem I am having.
I am trying to array a leaf shape around a curve but I am getting a warp towards the end of the curve.
Is there a better way of tackling this problem.
I have attached the file.
Also I am looking for a way to create the same arrayed pattern going from small too large. what is the tool to create this?
pascal
(Pascal Golay)
3
Hi Alex - this is what I get -
i.e. the base and target curve lengths do not match…
Is there any way you could attach the upated file?
Is that using array curve?
Perfect thank you pascal.
Last question I am trying to create this effect. Is there a way where I can go from large to small without manually resizing each leaf.
Tween?
pascal
(Pascal Golay)
8
Hi Alex - use Taper
on the input objects.
