Hello, I cannot get a shape to array along a curve in the file that Im working on. The shape will not stay on the curve? Any suggestions?
Thanks,
Rick
Thanks,
Rick
Do you have a sample file maybe? : )
Hi Rodrigo,
Thanks for your help. Here is the snap shot
https://www.dropbox.com/s/bspmk6m4xh4xdoq/Screenshot%202017-04-03%2009.09.28.png?dl=0 https://www.dropbox.com/s/bspmk6m4xh4xdoq/Screenshot%202017-04-03%2009.09.28.png?dl=0
Best,
Rick
sorry, I meant… .a 3DM sample file, makes it far easier to diagnose the situation and propose a solution!
See if it can help.
serie.3dm (2.6 MB)
After creating all the objects and oriented on the curve, if a particular rotation is required for each object on the curve, you can only rotate the green object (which has the history record) to copy and paste in place the objects and repeat for all objects.
Simon
Thank you Simon!
That is very helpful!
Best,
Rick
