Array an object along a surface adjusting to it
Hello, I want to make an array of an object along a surface following a curve. but what I get is what you can see in the picture. I would like for the elements that are in the bend to adapt to the surface. Is there a way to do it automatically or do I have to bend the individual objects?
Thank you!
Hi @Gabriel_Llorens
Take a look at the FlowAlongSrf command.
HTH, Jakob
… and check this forum for some similar topics, search for flowAlongSrf
there is also
_bend
command
I did it!
I used a combination of unroll and flow along curve.
Thank you all very much.
