It would be very helpful to have a Unit Conversion Calculator as an option similar to the current calculator. A lot of times I am working in inches and vendor brochures are metric.
Some basic conversions would be nice for length, area, volume, etc.
if you are drawing in inches you can type 5mm for a line command (works for other commands too) and it will draw a 5mm line in inches
Area and volume you can change the units it calculates in when you run the command. By default it is set to the units you are modeling in (set units = what units you need to calculate in)
-A
I didn’t know you could type 5mm in the command line. That is very helpful. Thank you!
