Hi guys,
Is there a way to reduce the opacity of objects in Arctic Mode? The trees are linked blocks and I would like to reduce the opacity of them.
TIA
H
The trees are bitmup texure or actual (speedtree) model3d?
Hi Alan,
Thanks for your reply. Iām still not getting the desired results so Iām maybe doing something wrong?
The trees are linked blocks of 3d models. Iāve isolated one to illustrate. See image below:
Iāve applied a default material to the tree and increased the transparency slider. Is that what you were suggesting? See image below:
Nothing changed. See image below:
Any suggestions?
TIA
H
Can be your tree mesh?
To debug the problem you can open a second Rhino.
If that work well then test the tree:
If is not working and the tree is still rendering bad, then probably is the tree.
Double check if there are flipped normals. Open the UVEditor and inspect the tree UV mapping. Try to export it small and re import it.
If is working well in the new Rhino, then is your Publicness file.
It can be an occlusion plane or similar.
How about setting a custom display mode for the trees other than Arctic? You can do that with SetObjectDisplayMode and then for example assign them Rendered mode and give them a white and transparent material.
Hi guys,
Thanks again for your replies! really appreciate it!
@AlanMattano - The meshes are clean. See report below:
RF_Check Report.txt (7.7 KB)
@polforeman - Thanks for the suggestion but Rhinora doesnāt allow me to change the display mode of the blocks either. See video below:
Any other ideas?
TIA
H
Ah, I see! Thanks for the video. It seems it isnāt possible to easily change the display mode for blocks, didnāt know that!
Changing the display mode within the block, before using it in another file, also doesnāt seem to work.
However, if you were to Attach the trees through Worksession rather than inserting them as blocks, you would then be able to change the display modes (just tried on my own file, it seems to work). Maybe that could be a solution?
I am able to set the block to be transparent if I change the original file, e.g. by double-clicking the linked block, editing the transparency in the new Rhino window, saving and exiting. This will update the transparency.
If this doesnāt work for you it would be great if I could try to see whatās going on in your file.
-David
Hi guys,
@polforeman - Thanks for introducing me to worksessions! Looks very useful and will explore more as Iāve never used it before now. You are right, I was able to change the display mode if I attach the tree through worksession but Iām still not able to change the transparency - similar to the linked blocks issue.
@DavidEranen - Your suggestion gives me the outcome Iām after. Unfortunately, it would mean changing the source trees. There are about 60 of them, each with 2 to 8 meshes with individual materials (thatās a lot of clicking and sliding
). Even if I bite the bullet and do them all, that would be secondary to the mess made with other files with the trees linked to them
Thanks again guys for your suggestions. Iāve learnt a few things trying to resolve this.
Regards
H
Loos like artic does not handle transparency or as a missing feature or bug.
As a workaround
what you can try, since there are a lot of trees with complex foliage and alpha blending problems, you can make imposters. In-game dev, imposters are just multiple planes containing the the image of the tree. You can make 360 screenshots of the tree and place some planes. So that fps will increase and that also let you apply transparency.
@AlanMattano - Sounds complicated but Iām intrigued. Iām delving into uncharted territory with your workaround.
Do you mind explaining a bit more how to do this?
@DavidEranen - Is Rhinora programmed to SetObjectDisplayMode to blocks or do you think this is a bug on my end? I see you work for McNeel, hence me asking you directly. I created a ātransparent arcticā display mode and using @polforemanās idea, tested it with a tree attached through worksession. I got the desired outcome but Iām not able to move the tree to the place I want (
). If it is possible to SetObjectDisplayMode to blocks that could be the solution - I can apply the ātransparent arcticā display mode to the block trees in my model! ![]()
TIA
H
Yeah, the problem with worksessions is that you canāt really move them around. So you would have to create all the trees you need in an extra file which you would then attach to your main file. Maybe you could try copying all your tree-blocks in their current positions to a new file and attach that one to your drawing, I canāt try it right now but I imagine that it might work?
And as you asked, from what I read here on the forum it seems it is not possible to apply custom display modes to blocks, so itās not a bug on your side.
Hi Pol,
If I attach the trees as blocks through worksessions, the setobjectdisplaymode would not work.
Never mind guys. Iāve made copies and exploded the blocks. It only took Rhinora 12 minutes to do this (
) and increased my file size to 4.2GB (I anticipate problems from now on
). Shame, as it defeats my reason for using blocks in the first place.
Hopefully the next Rhino update will allow display modes with blocks.
Thanks so much for all the replies/suggestions and taking your time to look into this.
BW
H
Hello, I created the following YouTrack item:
https://mcneel.myjetbrains.com/youtrack/issue/RH-54941 Display: Canāt change material of linked block
-David
Thanks @DavidEranen .
Hello again,
It seems that in order to assign materials to linked blocks, the block-file needs to have the objectsā materials be set to āUse Object Parentā. This way, when imported as linked blocks, the material can be changed and things work as expected.
However! This doesnāt seem to work in Arctic mode. Itās a bug, and I have created a new YouTrack item: https://mcneel.myjetbrains.com/youtrack/issue/RH-55011 āDisplay: Linked block cannot be made transparent in Arctic modeā
-David
