I’m using archicad/ rhino live connection and I wonder how can I choose the surface of an opening. With deconstructing a wall I can choose surface of a wall, but not the opening area.
Does anyone know how to solve this Problem?
Thank you!
Thank you!
here is the not super-clean solution…
It seems there is no way (or i dont know it yet) to extract dimensions from AC_Window, so it has to be redone in GH.
Anyway here is the definition attached.
Just Set Walls and Set Windows at the very beginning…
Best
Used versions: AC 21, RH 6, Gh 1.0, GH-AC connection (6002)
Wall - Window.gh (152.7 KB)
Hi @Jakinta
Thank you very much for your help. It is really helpful and works nice
Cheers, Noora
@Jakinta
I had the same issue and also build a workaround in GH. It’s actually not very satisfying that the dimension of the opening is not directly accessible via extraction, I feel. I think your script is a lot cleaner than mine
