Applying a linetype makes hard to pick curve
I am experiencing a strange phenomenon in the latest WIP. If I draw a curve in Wireframe mode, the curve has a certain default print width. I have a 4K screen here, so I would say it’s around 3 px using V7 for comparison. If I then then apply a linetype - say dashed - the curve width goes down to 1 pixel, and it becomes very difficult to actually pick the curve via a mouse click - I have to crossing select it.
If I set it back to continuous, it goes back to the standard width and becomes easily pickable again.
I am testing in a bog-standard default version, all display modes are default. Latest WIP.
Hi Mitch, can you send your SystemInfo, I cannot reproduce this on my end.
Rhino 8 SR0 2022-12-27 (Rhino WIP, 8.0.22361.13135, Git hash:master @ c51c915253258ed1c83aaed86199b3e81cefede0)
License type: Not For Resale Lab, build 2022-12-27
License details: Cloud Zoo
Expires on: 2023-02-10
Windows 11 (10.0.22000 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 12-5-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 527.56
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-5-2022
Driver Version: 31.0.15.2756
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.22361.13135
C:\Program Files\Rhino 8 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.22361.13135
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.22361.13135
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.22361.13135
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoRoslyn.rhp “RhinoRoslyn” 8.0.22361.13135
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.22361.13135
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCPython.rhp “RhinoCPython” 8.0.22361.13135
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.22361.13135
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 8.0.22361.13135
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp “SectionTools”
do you have by any chance display scaling set to something weird like 150% instead of 200%?
I’m running 100% on 1440p and having no issues on my side.
@Gijs I wish one day to have Rhino Systeminfo to show the windows display scaling, this may help us tracking every possible problem.
Yes, and I don’t consider it ‘weird’, it it the recommended display scaling for 4K monitors (27") under Windows 11. I have two 4K monitors connected to this 12Gb RTX 3060.
I updated my video drivers and blocked the RhinoArtFileExplorer plug-in which was seemingly still enabled. SystemInfo updated above. No change in behavior.
I don’t think it is related to scaling. I tried on couple machines with other scaling than 100 (one is set to 125) but I cannot see the phenomenon that the curve thickness changes.
Hi Mitch -
I’m not seeing the thickness change here but don’t have comparable hardware to test with.
I’m seeing the selection issue and will write that up.
RH-72212 Selection: Somewhat hard to select a curve with a linetype
