Hello, everyone. As a new guy, i want to apply some pattern(example picture) on this brep which have three surfaces. Normally, we get the base surface from rhino by one surface, but i have surfaces from alias software. If the base surface is this kind of brep, what should i do, surface morph doesn’t work on brep. please give me a hand, thanks!
Hi Quan,
Very thankful to your expertise. Based on your script, i have made some test that has right direction for my intention. However, i have some problem when visualizing the outcome, there are some strange frame line at the end of new shape.
Still the same.
And please internalize the geometry, don’t upload 3DM.
I am unsure if this is the reason, but if you use a coordinate system XZY, try changing it to XYZ.
Adding this pattern to a polysurface is remarkable. I suggest you make this to the gallery, so people will know this kind of thing is possible in this way.
I personally tend to think those elusive curves are just rendering artifacts.
But let’s invite some users much more experienced than me to look into this.
Garbage in, garbage out. There are two things here. In Alias the Render mesh seems not very dense. Other than that the highlights look quite bad. I guess this is because of the mess you see on the Rhino images in first place. You either need to rebuild the surface properly, which will likely even destroy the positional continuity. Or better, you create those surface clean from the beginning on. Its not an easy task in Grasshopper, due to crappy surface tooling, but its doable. Other than that, you can always create as much as possible in Grasshopper and do the rest in Alias manually. It depends. But the problem with most plugins is that they yield horrible geometry. It basically starts with the curves. You need to ensure to maintain light-weight curves and surfaces from beginning on. After each deformation (e.g. when projecting) you need to refine it again.
And if you ask now, why can’t I provide a solution, then I can answer you that a professional solution takes a week of work and someone with lot of experience in modelling and Grasshopper. The trick is to know the manual modelling process and how to work around the Grasshopper limitations in order to automate this. It highly depends on the geometry and the pattern, so there is no universal solution.
