I have a working Grasshopper that requires a brep for distribution across a surface. When I set the PolySurface as one bRep it works perfectly. I need to include the 2 surfaces in the distribution but can’t figure out how to include them. Setting multiple bReps does not work for the surfaces as I get just the first instance of each surface down the target surface. In that case, the PolySurface still distributes properly but the simple surfaces do not go along.
I would change the input component if appropriate but I need to keep this geometry together. I also need to be able to select just the 2 simple surfaces for layer change after I bake the distribution.
No, I am trying to keep the polysurface and 2 simple surfaces together so that I can distribute them across a surface by Grasshopper script.
Thanks anyway.
it depends on your distribution technique, which is why as pascal asked you should post the GH The solution could be to group the geometry, or something involving data trees depending on how your definition works.
Thanks MUCH - that works. It took a while to pare it down to the minimum, but I can move forward now. It does seem like grouping is necessary but I wonder why Group then UnGroup gives the desired result to the list.
