Having trouble using apply displacement for some reason. I must be using incorrect settings. What are the safest settings to use in MM?
Thank You,
Dave
Thank You,
Dave
Hi Dave - can you post an object and texture that shows the problem?
Hi Pascal,
I have two objects in my drawing. One is complex and the other is simple. I cannot use the graphic z,jpg with applydisplacement in either. The editing dialog box always pops up. I don’t want to edit, I just want to apply.
When I apply, no displacement happens.
Thank you,
Dave
Hi Pascal,
Pls forgive me for taking up your time. The .3dm file I tried to send was too large.
In the mean time I was able to get applydisplacement to work on a closed polysurface. You have always been helpful.
thanks again,
Dave
