Can I Unfillet?
Wow, 19 months away from Rhino has really taken a toll. Is there a way to unfillet an edge?
On a box you can by creating a bounding box…
On something like this?
arch.3dm (193.0 KB)
I haven’t looked at the file but the shape seems to be ‘planar’ / you can take some of the edges or create a section and extrude a fresh object
You may try ConnectSrf with corresponding surfaces. Fillet itself could be just deleted.
I guess it’s not as simple as a one click. I was hoping for something like “Delete hole” in Solids. Most off the places I want to use it will be easier enough to recreate from any number of tools. Thanks anyway.
use silhouette then extrude
the follow workflow will re-alive the underlaying surfaces
_explode … the entire object
_untrimAll
_join … dirty, but fillets will not be joint to the surfaces you need
_hide … select the PolySurface you need with one click
_delete … everything else - mostly the fillets
_show … above PolySurface again.
it is not closed because of the small surfaces at the lower end.
subselect (cmd+shift) those lowest surfaces
_delete … them
_cap … to create them again.
took me 3 times longer to document the workflow then to do it.
The edit option for FilletEdge looked promising as I was able to remove the fillets. But when you end the command some surfaces are deleted. This feature could use some attention.
I agree that Edit for FilletEdge is freakin amazing, but it rarely works, or only when applied immediately.
The …deleteFaces script of xRemoveTrim / xDeleteFaces | Food4Rhino can do it.
xDeleteFaces
That’s pretty cool. Exactly what I was looking for.
