Hello, you can see that on this part I have put a small edge fillet around the outside top of the part. Now I have discovered that that whole edge needs to be rounded. I’m trying to figure out how to edit that fillet out, and put a line along the center of the edge clear around the top of the part that I can pipe around. Everything I try ends up in a big mess.
Can someone point me in the right direction?
Hi Rex - in Rhino it is not a bad idea to do all the ‘finish’ filleting on a copy of your part so that you can go back to the un-filleted version. In this case, I’d say it will take a bit of work… If you’re lucky you can
Explode
Delete the unwanted fillet surfaces
UntrimBorder all the remaining surfaces
CreateSolid from these.
Otherwise, individually untrim and re-intersect and trim the faces that are up along the filleted edge. Feel free to post the file, someone may be able to take a swing at it. It’s pouring rain here.
