Any way to reset the 3MF export? Mine seems "corrupted" maybe
Is there anyway to reset the 3mf export in Rhino 8? I have been using this with great success to 3D print using Bambu Studio. However, starting today, if I export 3MF and import into BS, when sliced it gives me a critical error of the block fonts interfering with the main model. I grabbed a model I made before and imported into BS and it worked fine, so something changed from a week ago to exports now. If I leave out the block fonts there is no interference. If I include them, error.
Attached is the original Rhino file.
Fan Panel.3dm (7.5 MB)
Hi Bill,
Thanks for the file. Good news is there isn’t really anything in the 3mf exporter to corrupt — the only settings it remembers are the metadata fields and a move-to-positive-octant toggle, and that one moves everything together, so a reset isn’t the fix here.
This is what i found in your file: the block font solids sit inside the panel’s volume (they run z 0 to 0.027" right where the panel occupies 0 to 0.641"). So the exported 3mf has separate solids that overlap, and Bambu Studio flags overlapping objects as a conflict at slice time. Overlap is only allowed between parts of one object.
Lets try these:
  1. When you import the 3mf into Bambu Studio and it asks “load these as a single object with multiple parts?” — answer Yes. Parts of one object are allowed to intersect and BS merges them when slicing.
  2. Or in Rhino, BooleanDifference the letters out of the panel (keep the letters with Delete input = No), so nothing actually overlaps, then export.
  3. You can check the overlap in Rhino: select the panel + the letters and run Intersect — closed curves means the solids really do interpenetrate.
Did Bambu Studio update on you recently, or did you maybe tick “remember my choice” on that import prompt? That would explain it working last week and not now. If none of this sorts it, please post one of the failing .3mf exports and your BS version? Thanks!
Man! The way you folks respond and how quick, professional, and friendly… I love this program!
Okay, I did have a different response ready, but while I was writing it I decided to do some more tests. And I want to say THANK YOU for teaching me about Boolean Difference! I have been using Boolean Split and deleting the result all this time. And also for Instersect. :slight_smile:
But this is what I found. I did the Difference and the same error in BS. Then I created a new file with a simple cube and did the same block fonts and Boolean Difference and the export worked perfect. So now I decided to copy the object with the grill in Rhino and move it over next to the original that has the grill and try it again with the same block fonts. This time, on the copied object, the export worked perfect! I don’t have the talent yet to determine what was wrong with the first solid, but this seems to have fixed it. Sweet!
I wouldn’t have tried any of this if you guys did not respond to this forum message. I’ve owned Rhino since June 2023, and even then you folks helped me decide if it was right for a hobbyist (who is now retired). Your customer service is the best, hands down, and your program rocks!
Thanks for all the help and God Bless!
