I’m having trouble exporting a model as a 3MF file in Rhino. Initially, I was receiving errors about invalid objects during a geometry check. These were related to ON_BrepTrim::seam issues, which I successfully resolved by repairing the geometry. All objects are now valid according to the Check command.
However, when I attempt to export the file as a 3MF, I receive the error: “File writing plug-in failed.”
I’ve tried the following steps without success:
Verified that the 3MF Export Plugin is enabled in Tools > Options > Plugins.
Simplified the model by converting it to a mesh and reducing the mesh density.
Tried exporting a different model that I was able to export as 3MF in the past, which worked successfully.
I tried attaching my 3dm file but it says it is too large. I tried putting it in a zip folder and its still too large. I’ve pasted below the output for the SystemInfo command:
Primary display: Intel(R) Arc™ Graphics (Intel) Memory: 128MB, Driver date: 1-13-2024 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4080 Laptop GPU (NVidia) Memory: 12GB, Driver date: 12-3-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.36
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-3-2024
Driver Version: 32.0.15.6636
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
When you do a SaveAs you’re saving all of the geometry, even layers that are turned off. The neck of the robot and some objects on the turned off layers have mesh topologies in them that are invalid. Those are something Rhino creates, so it is a Rhino problem, but the 3mf exporter just bails if it encounters a bad topology so it doesn’t crash. I don’t know why extracting the render meshes works since the exporter gets the render meshes on the fly from the objects. I guess one thing is you’re not selecting the objects on layers that are turned off. I changed the render mesh settings (moved the slider all the way to the right) on your model and then did a SelAll (without turning on the layers that were off) and then Export and I was able to save to 3mf. That must have been enough of a change to fix the topology for the neck.
I’ll see about isolating the neck so that someone here (much smarter than me) can figure out why a bad mesh topology gets created.
