I have 1 Naked Edge in the model. When I Mark the edge, I can’t zoom in close enough to see more than 1 point. ! _RemoveAllNakedMicroEdges does not fix the situation. is there any way to adjust the size / tolerance of that command to make it remove larger gaps than default?
Hi Robb - I don’t think so - but in any case not all tiny edges can be fixed by this tool - your edge may not be a loop for instance, but a very short edge.
Thanks for the thoughts about the display settings. I am referring to the fact that your control(?) points seem to be right at the edge of the surface and show per isocurve. Mine are off the edge of the surface and do not align with the isocurves. I did shrink the surface.
